Discuss pex fitting to rad in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Mr Wilson
have 20mm pex running behind wall and looking at ways to connect to rad ( horizontal connection )... obviously only want as few connections in wall and 1 if possible. was planing of using a copper stub out elbow using a crimp connection if i can source them to germany. not sure if this (copper)will look a little ugly sticking out the wall ... would prefer chrome pipe but to connect this would require 2 connections either side of an elbow and the chrome pipe would have to be compression fitting.
any thoughts on this what are you pros using mabye theres a pex fitting im unaware of.
cheers
What make of pex is it?
hmmm good question which would require a walk down to the shed...that will ave to wait till tomorrow ... i do know its us made or at least distributed from there ... will look at that tomorrow ...
actually do you mean manufacture of pex or type ... type is Pex Al Pex
cheers
Just google pex to copper and a few adapters come up
7630d1357654402-please-help-me-understand-pex-fitting-10831d1217973736-pvc-copper-interface-200702_pex_009.jpg
cheers shaun ive looked into all these fittings as i cant find a supplier of copper stubs in germany. it seems like the full range of pex fittings are in USA even the crimp fittings shown in above pic i cant get those type of fittings here there a little different with a shorter barb...
im thinking ill just have to use an pex crimp elbow to copper and solder the copper connection therefor making my own copper stub.
all the same i think ill figure it out...
cheers
cheers
what make of pex do you have?
cheers
Amber in Deutschland becomes Sie a deer materialised die Sienzum pressed verwenden kƶnnen ... Muss doch nicht unbedingt pex sein oder ?
Wir haben doch echt hochwertige press fittinge und die passenden Plastik Rohre dazu.
these are the types of crimp fittings the the supplies sells with my pex ... i beleive they aluminum probably plated nickle
sorry matchless my Deutsch aint that great yet something about a deer materializing that i can get use to???
now i understand you mean mlcp (multi layer pipe) and the fittings are crimp right if so have a look at these
[DLMURL]http://www.uheat.co.uk/uponor-mlcp-copper-adaptor-fittings-20x22mm/[/DLMURL]
[DLMURL="http://clmheatingsolutions.com/product/wall-plate-elbow-fitting/"]Wall Plate Elbow Fitting - CLM Heating Solutions[/DLMURL]
Sorry my bad the keyboard wasn't right settled.
I just mentioned that you can get easily very good / high standard plastic pipes in Germany as well as fittings ... We have got loads of crimping stuff and well insulated pipes for crimping
[DLMURL="http://www.uheat.co.uk/uponor-mlcp-copper-adaptor-fittings-20x22mm/"]Uponor MLCP/Copper Adaptor Fittings 20x22mm (Pack of 10) - uHeat[/DLMURL]
ya correct multi layer pipe .. Pex Al Pex = pex aluminium pex ....
cheers fellas ... would you guys recommend these crimp over compression for behind wall... or better put wouldn't compression provide better grip
crimp and over compression crimp would take much much force to pull off
why not use these and connect the pex straight to the radiator valve [DLMURL="http://www.uheat.co.uk/uponor-bsp-compression-adaptor-mlcp-16mm-x-1-2-ft/"]Uponor BSP Compression Adaptor (MLCP) 16mm x 1/2" FT - uHeat[/DLMURL]
you can use these with compression fittings as well if you haven't got a crimp tool
cheers mate ... i did look at those but not sure if i want pex to be seen visually.
looking like ill use a crimp elbow to either soldered copper or threaded chrome
Reply to pex fitting to rad in the Plumbing Jobs | The Job-board area at PlumbersForums.net
