Discuss Orkli 2 port motorised valve in the Ireland area at PlumbersForums.net
Hi
has anyone ever come across a orkli 2 port motorised valve60520604(silver case) I only need actuator but finding it hard to source exact replacement, also do you know if the actuator can be replaced on this model without draining. Im only familier with honeywell and drayton. If not no problem ill just drain down and fitt honeywell.
thanks
looks like a re badged esi
Reply to Orkli 2 port motorised valve in the Ireland area at PlumbersForums.net
Hi. I need a new toilet supply line but donā€™t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic nut about the same size as the one going into the cistern but has a different thread. Attached is a photo. Can you advise. Thanks.
Hi, Can anyone advise as to why the cold water to my bathroom keeps airlocking? This originally happened about 12 months ago and has happened 3-4 times since. Itā€™s an upstairs bathroom, fed from a tank in the attic. The tank is about 8 Meters away and feeds a bath, sink and toilet. The tank...
