Discuss Omg which Bathfiller is best? Aqualisa/Geberit/ Hansgroher! in the USA area at PlumbersForums.net
Ruu
We are stuck! And really need help sorting this family bathroom .. we decided on a Bette steel bath in a tiny bathroom love the idea of bath fillers have great water pressure(new unvented boiler)But Are bathfillers a good idea in the first place??!! - very impatient at the best of times - so any flow restriction is a worry. Initially seduced by the idea of the tap valves being in the same unit as the overflow but are a bit scared off by nine being about. Tried and tested is usually the best way to go. A plug never goes wrong!What are you recommendations please !!!!!?? We really need them. If Bathfiller which pls and then would u marry with Deck taps ? Which would u go for? Would you mount in the Bath or just behind ?we have a little 100mm ledge to makes up the length of the room. Really need just to get it done and would really appreciate some help if you can. Thank so much All
If you want to go with an exofill design I would go undrilled, wall mounted controls and an undrilled bath.
I prefer hansgrohe for exofil and brassware.
However, wall mounted taps need a bit of experience to get right...
[/QUOTE ...
do the exofills work ok ?
do the exofills work Ok ? Decent flow rate etc?
[automerge]1593307741[/automerge]
perhaps Deck taps might b easier to fit ... i’ll Check it out .. thanks for the time BenG
And make sure you don’t go down the 🤡 route by tiling in the side of the bath with no access...
No! I would never do that! Sorry BG some of my replies are not being posted for some reason.
It’s definitely harder to fix the taps to the wall than the Bath ... access wise ... there’s about 8 cm over after the width of the Bath ... walls are block work ... so I’d have to build tiled box 8cm in depth behind the Bath with a removable front for access(actually you could probably get access from under the Bath(removable bath panel) build the tiled 8cm box up enough in height to give you wall taps.
A middle ground cld be deck taps and keep the 8cm tiled box almost flush with the Bath
Are exofills a good idea? Do they work well in the real world ? Can’t find any videos or reviews or anything accept back a few years on Mumsnet complaining about flow rates and waiting ages for a bath! (I hope this reply actually posts) Thanks BG!
Reply to Omg which Bathfiller is best? Aqualisa/Geberit/ Hansgroher! in the USA area at PlumbersForums.net
