Discuss Old waste pipe size help in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
came across this old push fit waste pipe. Stripped out the old shower and it was a 40mm waste pipe siliconed in the fitting.
The fittings at floor level so I’d be looking to bend (90 degrees) straight away so I can get the lowest possible shower tray.
Could someone advise what I could use you as 50mm pipe is from the standard screwfix is too big.
Any help would be greatly appreciated.
The old piece of pipe is left in there you can see the outline of it is that roughly the same size as 2” waste pipe ?
Reply to Old waste pipe size help in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
