Discuss Old Stopcock on Lead 1/2" ~ 3/4" in the USA area at PlumbersForums.net
Stanios
Encountered this old stopcock, male threads both ends attached to female fittings that are welded onto lead pipe both ends. Looked like 1/2", took it off, closer to 3/4" but quite a bit smaller than 3/4" still.. Photo is not of that stopcock but looks exactly the same (forgot to take a snap)
Took off the headgear bit I've done this before but new innards from new stopcock didnt quite fit.
So option 1 is to get exact replacement. Option 2 get any "old style" stopcock take the top bit off and swap. Any help would be much appreciated!
Had a similar issue a few years ago, you can't get new parts for these anywhere. I also asked on here, best advice I got was go to local scrap merchants and check out the brass bins for spares.
With mine the handle had snapped off so couldn't just fix it. What's wrong with it, not fixable?
It will most likely be on 1/2" x 6, or 7, or 9 etc. (1/2" bore and weighs so many pounds per yard). Depends on pressure.
What's the issue with it?
Install a new one and lead lock it either side
Water leaking out. I stripped it and chucked all the ptfe it could handle leak is no more but its hardly a functioning stopcock. Looks like I'l have to fit two leadlocks!
Reply to Old Stopcock on Lead 1/2" ~ 3/4" in the USA area at PlumbersForums.net
I wonder if anyone can help, I've tried several plumbers merchants to no avail. I have removed an old stopcock, (which seized long ago, with a...
2K
Hi All, In Dec 2023 I had my annual boiler service and asked the plumber to change 2 radiator valves as the radiator in the toilet downstairs was...
Hello, I am renovating a small bathroom in an apartment on the 5th floor. Heating is electric, no gas or oil. I have four (related) questions...
I have read a few threads including one by Debbie Stano that were similar to my issue but that thread stopped a while back without any resolution...
Hi All Looking to replace taps on a cast iron bath, accessing them is near impossible (i even had to remove toilet). The taps are old lifter type...
4K
