Discuss Old Pegler basin tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Sox
Hi Guys,
I have a old Pegler basin tap which is leaking. I want to replace the washer but I have no idea how to get the cross top handle off. The top of the handle has a red hard plastic indice which I tried to remove to try to get to the screw but it seems impossible to remove. Any ideas on what I should try?
Providing it does not have a screw in the side of the cross head, it means you have to force the indice out, possibly destroying it in the process. Get that off and it's then a good old-fashioned DIY job to strip, replace washer and GREASE IT UP!
thereisawizza - Thankyou for your reply. No screw on the side so I think I will take your advice and force the indice out. I was going to try this first but I thought I didn't want to damage it. But if there is no other way I will just have to go with it. Thanks again.
On some of these old taps sometimes you can get it apart without removing the X-head, wind it right out and you may have enough room to get a thin jaw spanner in to undo workings
  • Agree
Reactions: deg
With respect to Wizza, please DO NOT just shove any old grease in there. it MUST be silicone grease as normal grease will attack o-rings etc.
Lastly, replace ALL O rings. cleaning up and lubing their bearing surfaces with SG too. That way they will last years and years and years and... ;)
Good point!!
Reply to Old Pegler basin tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes a squeak noise as I turn it on or off, left tap is 100% perfect and noiseless. This grohe tap is like one unit, so no screw notch or way I can remove...
Hi guys....we have an old Astracast sink top....I think its a composite sink....has a big single bowl. My wife thinks it looks scruffy....looks ok to me.....sound but the bowl has seen a lot of work. So she wants a new one...Astracast it seems are no more. The problem is its size.....looked...
