Discuss Oil flow to tiger loop in the Plumbing Jobs | The Job-board area at PlumbersForums.net
BRJ
Our burner locks out. The oil flow coming into the tiger loop appears too slow to keep up with pump demand and so it runs out. If left for a few minutes the oil level in the tiger loop builds up and allows the boiler to fire again but only for a few minutes. This occurred for the first time 4 days ago at a coincidence of (1) a delivery of fuel was made, we hadn't run out and (2) following a week of outside temperatures of - 5 to -12 C. The temp outside has now been + for a couple of days. Any ideas ?
If the boiler was running when the oil delivery was pumped into the tank it could have stired up water / dirt from the tank bottom and been sucked into the filter and water can also go past the filter and into the pipe going to the tiger loop . This can then freeze and reduce the flow of oil to the boiler .
Try cleaning the filter out or pouring a bucket of hot water onto the filter and pipework and see if it helps .
Reply to Oil flow to tiger loop in the Plumbing Jobs | The Job-board area at PlumbersForums.net
