Discuss NVQ level 2 PP1 soil and waste pipe x dimensions in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
arise
Hello, Has anyone got the x dimensions for the PP1 question in the NVQ level 2 college book. I've spent a day and a half on this and no one else has started it yet at college. So far i've only got 3 of the dimensions correct 2 for 32mm and 1 for 40 mm the soil pipe is hard cos you only get a 2-3 mm tolerance and my tutor just puts a tick if its right and that's the only feedback he'll give me.
any help appreciated
Andrew
i think the pp1 is in the tech cert book, not the nvq port folio, may be misleading people here, clear that up and you might get more replies, cheers
The x dimensions vary by make. You need to understand how you measure them otherwise there is no point in doing it surely? FWIW the x dimensions is the difference between the centre of one socket to the ful socket on the other. Hope that helps :)
i always measure centre to centre, then work out accordingly
when i did alot of steel i notices that centre to face was the same as end to end on half inch, made measuring easy. on 3/4 you had to knock off 1/8 of an inch
Reply to NVQ level 2 PP1 soil and waste pipe x dimensions in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down through slab and out through deadwork into a manhole. I will work out falls from manhole and set the height of the waste water system as required. For...
Hello I am looking to install a slimline dishwasher (integrated) into a cupboard in my kitchen. The depth of the dishwasher is 550mm and the depth of my cupboard is larger than this. The issue, however, is that the waste pipe which leads from the sink (next door cupboard) comes out quite a...
