Discuss Noisy Radiators! Please help! in the USA area at PlumbersForums.net
Hi
I'm new to this forum and the only reason I've joined is so somebody can help me with noisy radiator issues!
We moved into this house in March and we've been experiencing issues with two radiators in the upstairs bedrooms ever since.
We can hear the sounds of water sloshing and some other weird noises.
We have an Ideal Atlantic 24 boiler and these two radiators are brand new. TRVs have also been replaced recently.
Our system has been power flushed after we moved in.
My OH thinks it's to do with the pipe work whereas I'm thinking it's the boiler.
It could also be air in the radiator but would it make these sounds?
Also we have a radiator in our house that doesn't even get any heat. Engineer said its a dead pipe. Wondering if it's related to that?
I'm at my wits end here.
I've uploaded videos to help.
Can some please help! Thank you
Those don’t sound good, and could be trapped air, and with some radiators they have to be fitted the correct way around, so could be this as well (I have no experience of those types of rads though).
The radiator that doesn’t heat up, do you get water from the bleed vent? It could be a balancing issues, stuck/faulty TR pin (if it has a TRV), piped up incorrectly.
I personally don’t think it’s the boiler making the noise.
Ah, so that rules out my question to Shaun. Sorry I'm a burner service and repair technician, I'm not overly familiar with designer radiators.
Have you tried bleeding the radiators, have you had air problems before?
I'm not 100% sure what the issue is but I think the engineer said it's because no water is reaching that radiator. Could perhaps be because of a collapsed pipe but really can't say
First port of call would be to delete the rads and radiators valve eg trv and lockshield on the worst one to prove either pipework issue or trv / rad
Eg with 2 elbows and a piece of 15mm tube
Hi everyone
So I made quite good progress with this. I ended up buying some Aladdin auto-vent valves and installed them on the two noisiest radiators
Now whilst the heating is on there is very little noise!
However I'm not sure it's completed fixed the issue.
When the boiler comes on and off I can still hear water gurgling in the rads. So when the boiler comes on, I can hear the radiator filling up and when it goes off I can hear the sound of water again - almost as if the rad is emptying. I don't think central heating works that way
I've done some research and it could be the pump speed on my combi boiler is too high and causing the rad to fill up too quickly. I have an Ideal Atlantic (installed by the previous owner).
Would adjusting the pump speed help with the noise?
Hi everyone
Does the noise vary depending on how many TRVs are open? Your pump is probably on full speed and depending on the size of your system you could get away with a lower speed but the combi may require full speed for hot water production. Give it a try and turn down one speed to see if it makes a difference and if it's okay go one more (assuming 3 speed pump). Check in case the hot water flow is reduced.
I have an Ideal Atlantic 24 and can't see how to adjust the pump speed using the controls. Could it be behind the cover? In which case I'd need to get an engineer in
Try opening the lockshield a 1/8 of a turn more
What is the boiler pressure when cold/hot with CH on?, you might try increasing it by 0.5bar with the filling loop but not above 2.5 bar with CH system fully hot.
It's running at 2.0-2.2 bar when off and 2.6-2.8 when the CH comes on
I probably need to release the pressure a bit but not sure if that's the reason for the radiator noises
Reply to Noisy Radiators! Please help! in the USA area at PlumbersForums.net
Would like some help please as my Drayton Wiser system is a mess. I had 2 TRVs in the lounge, one in the main bedroom, the rest of the house - 6...
Hi, Sorry if question already answered in previous posts, but I can't find a solution to the below: We recently moved house to a new home that...
I have recently bought my own house and decided to redo the kitchen. There was a radiator in the room already but I wanted to move it. I extended...
Desperate for some help! Be a life saver of someone can help as suffer from a high intolerance to noise. Moved into new house 1940s (copper...
Hi - we have had new radiators fitted about 6 months ago ("DuraTherm Horizontal Double Flat Panel Designer Radiator" from plumbworld - sorry, this...
