Discuss no permanent live required in potterton boiler?? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
E
egginyourface
Ive just finished wiring up a potterton promax boiler and read in the manual that no permanent live was required in the boiler if the system is fully trv'd.
So basically there is no pump over run after boiler is shut down.
sorry if this a bit vague
pg 14, y plan
[DLMURL]http://www.potterton.co.uk/docs/Potterton_Promax_Heat_Only_HE_Installation_and_Service_Instructions.pdf[/DLMURL]
no permanent live required on this boiler, if all the rads have trv's then wire the pump up to pf terminal on the boiler to get pump overun.
Reply to no permanent live required in potterton boiler?? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
Hi, The outlet of all my radiators are at 55°C, but the boiler keep showing the Return Temperature is 60°C (and keep raising at 1°C/min rate)...
Renato
R
Hello. I've just replaced our old Potterton EP2 CH controller with a Drayton Wiser HubR (& peripherals). The old backing plate wasn't...
Hi all. So I have just moved into a new house with a Potterton boiler in it. Great big thing!! lol. I want to fit a Hive to it but it obviously...
1K
Hi I seek some advice on replacing an existing regular boiler. I currently have an old Potterton 10-16 Netaheat electronic, which is around 35...
Dear All New member here, coming looking for help. A few weeks ago I had work carried out by a British Gas Homecare service technician. It...
