Discuss No hot water unless the heating is on?? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
H
hunty2k10
I've been working on a vaillant turbo max, I changed the inbuilt time switch because they could only put the heating on manually, I waiting and made sure it was coming on with the new switch as it wasn't before, customer has now rang and said she can't get any hot water with out the heating being on aswell, I'm baffled!
Ate you GSR
Have you been doing fault finding long?
what switches the hot water on on this model diaphram flow switch or hall effect? id look at those first
You would really need to go look to be honest as could be a number of things. Relay stuck on the board? Gas valve not modulating to max, flow switch etc etc
You sure the hot waters getting hot and not Luke warm? Could be that the hot waters not working at all but gets heat transfer to make it Luke warm when the heatings on. Just because the tenant says its working when the heatings on doesn't mean it is.
I can never remember Vaillant models, but is the Turbomax the old one with the tall brass diverter valve behind the pump on the right hand side? If so you need to check the lever is operating the microswitch on the right hand side of the diverter.
If it isn't making contact with the switch, you need to order a diverter valve repair kit as the diaphragm is most likely perished.
If it is making contact, does the hot water demand LED light up on the control panel? If not, the microswitch may be knackered or the PCB.
If it does light up, does the boiler fire? If it doesn't, possibly a board fault. If it does fire, may be looking at a few different things.
If it is a newer Vaillant, they use an "Aqua Sensor" and a motorised diverter valve instead of a hydraulic set up, so you need to establish whether the boiler is recognising a demand or not, if it is then check whether the diverter is operating correctly or not.
On a simpler note, as Zeebeedee said, check whether they have no hot water at all or just warm water, the newer models have a pre heat function on the DHW, which may have been turned off when you fitted the timer, with this turned on, it gives hot water for about 10-15 seconds, it may have been turned on before hand and masking an existing fault with the DHW. To enable it, turn the hot water stat all the way down and then back to the desired temperature, an LED or a tap symbol should appear to confirm pre heat is on.
Reply to No hot water unless the heating is on?? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Have a sytem boiler with unvented cylinder with 2 heating zones plus hot water in a house we moved into recently. To start with we were always...
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new...
MartinPod81
M
M
I've got a heating boiler which heats up the water in a tank located in a cupboard upstairs and then from there I get hot water & hearing. I get...
Hi, We moved into a new property yesterday and are a little baffled by the heating/water tank situation. The previous owners unhelpfully left any...
 Our heating stopped working today. We've got a Veissmann boiler that's under a year old, and an older Megaflow cylinder, and two diverter...
