Discuss No hot water - Gledhill Boilermate OV A Class in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Stewartk
I have a Gledhill Boilermate OV a Class. Boiler switched off, gas board came out to check everything boiler started again. Since then Central heating is working fine but the hot water is not consistent. I get a small amount of water, enough for a very quick shower, not enough for a bath. If you then wait a while the water does heat up again but not does not last long. Gas board said it is something to do with the 'Switch' system.
Get in a decent gsr and don't waste your time and energy on them clampetts
Reply to No hot water - Gledhill Boilermate OV A Class in the Plumbing Jobs | The Job-board area at PlumbersForums.net
My heating system comprises an Ideal Logic 12 boiler located downstairs and a Gledhill OV SOL cylinder located upstairs . The problem is that when the Gledhill controls for the “hot water” and “central heading” are turned on the Ideal boiler makes a constant “clicking” noise and tries to start...
I have a 2 pump hot water tank (Flomax 180L fitted in '94) in airing cupboard system with an Ideal classic boiler (downstairs next to an external wall) which for the most part seems to provide excellent hot water. The central heating also works fine - though sometimes I think the radiuators...
The Water Board have just replaced the main water supply to our property. We have a ground floor combi boiler. The central heating system for the whole house is working as normal. Hot water is working as normal on the ground floor. However, there is no hot water to the first floor bathroom. This...
G
I've just bought a 3-floor house with a gas boiler on the ground floor and hot water tank on the middle floor. When I switch on the hot water at the timer panel, it works but it also heats up all the radiators above ground floor. I have to close them individually to stop this. The rads aren't...
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new well maintained Worcester combi boiler. We weren’t convinced the heating was working right and then got hit with a £610 energy bill for the first 6...
MartinPod81
M
