Currently reading:
No heats from radiators in first floor
Discuss No heats from radiators in first floor in the Plumbing Jobs | The Job-board area at PlumbersForums.net
deckins
Hi All I just installed new combi boiler after decommission an old back boiler I capped the flow and return connections and which were in fire place. I picked the flow and return from the radiators in kitchen close to the boiler when I commissioned the new boiler I had no heat up stairs should I joined the old flow and return together? All pipes are under the floor and carpet I can't see the old the pipes connection your advise will be very appreciated. thank you:sweatdrop:
there was a back boiler behind the fireplace and the feeding cistern in the loft in the kitchen there was a separate boiler for hot water
see without seeing the job is hard to give 100 % accurate help , but just link and see , i take it you have tried turning the hot rads of to see if the pump will send heat to the others , also was there any controls you have removed ?
Are the TRV's bi-directional?
I'm struggling to visualise what you've done tbh, I usually decom back boiler then use existing f+r to downstairs heating by linking them out in void next to fireplace and removing old pump etc under floor.
You might be getting poor circulation if you've tried to tee heating in to 15mm supplies on kitchen rad.
May be to close the hot rad and see if the pump will push upstairs.
I did connect the power flush machine up hairs and did not circulate but the worse I bleed the rads and there was water coming.
You need to go back and check out all old pipework and remove old components. Im guessing due to inexperience you haven't priced the job accordingly, but youll have to do it.
There has to be a CH pump to be removed, otherwise the old heating wouldn't have circulated, i usually find this on return pipe, under floor at left of bbu. There is possibly a gravity/non return valve on old pipes to the bbu. There's possibly an open bypass/link in system, look under floor on landing.
You haven't described the type of system, y plan, s plan or gravity HW pumped CH (most common round here).
Honestly you shouldn't be tackling these jobs if you haven't got any experience of them. Unfortunately the rise of the combi has led to lots of installers running round doing swaps with very little/no experience of real CH systems. If you're busy, try to find someone with experience to help you on jobs.
this highlights the failings of the training industry in regards to plumbing how could this system not have a pump its first year central heating layout stuff i can still see the line diagrams in my head for the various systems from when i was taught 40 years ago in those days we were taught plumbing and heating now their taught to get through the exam
Reply to No heats from radiators in first floor in the Plumbing Jobs | The Job-board area at PlumbersForums.net
