- Messages
- 156
could be the old feed and expansion pipes from the old tank that was in the loft so will never get that hot
Discuss No heat in airing cupboard in the Plumbing Jobs | The Job-board area at PlumbersForums.net
That makes sense, but if they are, then they probably are off the flow & return, so should heat well unless blocked maybe.could be the old feed and expansion pipes from the old tank that was in the loft so will never get that hot
sorry i wasnt replying to you but barrelboyThanks guys. Steveb, there's no rad, and the pipes are off the hot water circuit. jts - I'll check the gate valve, thanks for that.
Reply to No heat in airing cupboard in the Plumbing Jobs | The Job-board area at PlumbersForums.net
