Discuss No cold water in bathroom.indirect water supply. in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi.. I would appreciate your advice.
I am not get any cold water on the bathroom. Just dribbles in the bath and toilet..none at all on the wash basin.
The supply is from the cold water tank.
Thank you.
Reply to No cold water in bathroom.indirect water supply. in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi, I was hoping to get some advice. I live in a three floor house with a gravity fed cold water system for all of the bathrooms. The tank is in...
Hi everyone, I turned my cold water feed off in the airing cupboard which supplies only cold water to my bathroom but it also turned the water to...
For reasons that I won't go into. Is it possible to control the water flow to a cold water header tank without having a ballcock in the header...
Hi everyone, Could someone please explain if this set up is normal and what changed: Stopcock under kitchen sink turns off cold water supply in...
