Discuss New Water Supply - Domestic Connection Options in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a new 32mm MDPE supply pipe being fitted at my property and my builder and I have been discussing how best to connect it up to the existing 22mm copper water pipe inside.
There obviously needs to be a stopcock, meter adapter and drain-off valve in between the two.
There doesn't seem to be many options for connecting directly to a 32mm supply other than to reduce down to 25mm and taking it from there.
I've seen some all-in-one 'meter kit' options which include the stopcock and meter adapter with 25mm PE on one side and 22mm copper on the other.
Does anyone have any advice on best practice for connecting this up?
I'm thinking:
32mm MDPE pipe > Reducer (32>25) > Meter Kit (Stopcock+Meter) > Drain-off valve (copper soldered) > 22mm Copper pipe
Is there a better way to do this?
Thanks!
32-28mm adapter then reduced down to 22mm
What would I connect after a 32-28mm adapter? Not clear why I'd do this.
Has anyone got any opinions on the all-in-one meter kits?
Internally or externally meter
Depending on where your stupply pipe is
32mm elbow
Copper 28mm adapter for the elbow
28mm pipe
28mm stop tap
28mm to water meter connections
Then 28 -15 mm tee for your drain off
Then carry off in what you want either 28 or 22mm
Reply to New Water Supply - Domestic Connection Options in the Plumbing Jobs | The Job-board area at PlumbersForums.net
