Discuss New tail for old Peglers Radiator Valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I need to replace a radiator, one of the valves is a Peglers B.S 2767 the tail in the old Rad is proving very difficult to remove can you still get tails for these valves? As replacing the valve will involve a lot of work I have a Wicks 15mm x 1/2" valve but the treads appear to be different.
Hi Brad,
Is it large tail valve with 3/4” nut?
A photo would be good.
It should come out if you have proper ratchet radiator valve tool.
Reply to New tail for old Peglers Radiator Valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
Hi, I have an old steel water mains pipe (approx 45mm) that I need to connect to a new pehd water mains (25mm). I can't get at it to create a new...
