Discuss New rad sits out 10mm more than old pipes. Any solution? in the USA area at PlumbersForums.net
I'm trying to put in a new rad. But the rad sits about 10mm further from the wall than the old pipes come out of the ground.
I've tried taking away a bit of tile to push the pipes back but they are locked in place.
What I probably need is a copper pipe with a very small, 10mm, bend in it. Would that work?
Have you tried the wall brackets the other way around?
If they won’t line up, yes bending a little set in copper - to keep the valves vertical, is the usual method.
However as this involves altering the pipework below the valves it will require draining down.
Thanks. I took the ceiling out from below and was able to do a bit of jiggery pokery (technical term) :) and get it sorted. Pain though!
Reply to New rad sits out 10mm more than old pipes. Any solution? in the USA area at PlumbersForums.net
Sonya K
