Discuss New hob - alot of gas in the Gas Engineers Forum area at PlumbersForums.net
Hi I just had installed a new Bosch series 4 pgp6b5b90 gas hob. See attached videos of it turned on. It seems there's a lot of gas coming off it. Is this normal?
  • 20230104_010928.mp4
    32.2 MB
  • 20230104_010854.mp4
    54.3 MB
Normal the decent makes seem to have better flames
Looks normal to me. If you want to reassure yourself just check the gas rate, convert to kW and compare with the manufacturer's values in the instruction book. From memory, the burners visible in your first video have maximum outputs of 1kW, 1.75kW and 3kW.
Edit: You shouldn't be able smell any gas while it is operating. (I don't think that's what you meant but I shouldn't assume things where safety is involved.)
You're a star mate. Thankfully no I can't smell any gas just seemed weird seeing the reflection on the wall and worktop, not had that before with my previous hob.
Reply to New hob - alot of gas in the Gas Engineers Forum area at PlumbersForums.net
PSxxxxxx
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged...
