Discuss New Build House - Central Heating Issue in the USA area at PlumbersForums.net
I have just moved into a new-build house and can't for the life of me get all the radiators to come on at once. There doesn't seem to be any issues with the downstairs radiators but on the 2nd floor it's random, some days one radiator comes on, another day it will be a different radiator. Then on the 3rd floor, the landing radiator works but then the 2 in the master bedroom and the ensuite one don't work. I say 'don't work' they have come on since we've been in the house. Any advice/suggestions would be greatly appreciated before the kids die of hypothermia! (Apologies for the drama but it snowed yesterday). Please don't hesitate to ask if you need any further info.
If you have just moved in you should have no need to ask questions here!
Go shake someone from the builders/developers warmly by the throat you must have contact numbers use them.
Yes and from what I've heard it takes around 2 months for them to take any action. I need my heating now
Yes, I have 2 radiators on the 2nd floor and 2 on the 3rd floor that don't come on. Don't seem to be able to remove the thermostatic valve heads - the 2 on the 3rd floor don't have them
Sorry, what I meant was, are there motorised valves? You might have room thermostats controlling them, it seems odd on a new build not to have thermostatic radiator valves (trv’s).
Silly question: The thermostats on the radiators if TRV (google images if unsure) should be removable as discussed above. If you are not sure then best get in a pro. Now my real question: is there more than one wall thermostat? E.g.one per floor. That would imply motorised valves (see above) that might be stuck (job for a pro). I'm wondering also if any rads need bleeding or might be an airlock somewhere. Are any rads only hot at the bottom i.e. top full of air.
Now I'm afraid my real comment. I don't know who the builder is, but I'm assuming one of the big ones. I would personally recommend you get in a professional surveyor for a full structural survey (including the roof) on the new house, and any garage. NHBC publish all the standards your house should be built to, but a lot to read and I guess you have a job to do.
I think it is morally wrong that new houses are sold without any 3rd party independent inspection before the cash gets handed over. BCO should have done that for you of course but that function may have been done privately in your case. Compare with motor vehicles that you would probably not buy "sold as seen"?
Best of luck.
Cheers,
Roy (amateur all trades)
Sounds like a dual zone with room stat on ground level and one on top floor, hence, no trv’s in master bedroom. Usually 3rd floor on its own zone and 1st and 2nd on one. Though I have worked on one particular house type for Strata homes where for some reason the downstairs stat also did both landing rads on 2nd & 3rd floors.
Reply to New Build House - Central Heating Issue in the USA area at PlumbersForums.net
  • Sticky
I thought I'd create a master thread to move all of these similar threads into, over time like. If your central heating doesn't work boiler...
Hi everyone. I'm currently working on a job for a customer. their radiators are not all heating up. in total there is 12 radiators. 4 of these are...
Desperate for some help! Be a life saver of someone can help as suffer from a high intolerance to noise. Moved into new house 1940s (copper...
Hi, Over the past few months, my wife and I have noticed a constant pulsing sound throughout the house which is particularly noisy at night (this...
I have a home with an oil boiler in a garage turned into a flat, heating both flat and main house, running c plan with two pumps, two motorised...
