Discuss new baxi back boiler units in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Iam looking for some feed back on baxis condensing back boiler units, from people who have fitted and used them. Are they really as easy to fit as baxi say and are they as good as A rated wall hung boilers. I normally fit worcester boilers so dont know much about these.
the same question was asked last week or week before, some replies there.
search top right.
I reckon fitting the flue would be a bit of mare.
Is it the promax heat engine that's in it?
Reply to new baxi back boiler units in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all,new to the forum and hoping to get some guidance through the boiler minefield . We moved into a 70s bungalow last Feb,its got a Greensted 241 junior mark 3. The expansion tank has failed, also it has a Boss therm sender unit wired to it but the previous owner didn't leave the receiver...
Hi. I’m new here and due to have a new boiler fitted. Does anyone have recommendations or thoughts on either the Worcester 8000 40KW Combi or the Baxi 40kw Platinum or the Valliant EcoTec Plus 838. The Worcester is the most costly but I’m happy to pay more if it means a better boiler (long term...
Hello everyone, Baxi Ecoblue System boiler which was recently serviced just before Christmas. There has since been a constant but slow drip coming from the black nylon plastic drain plug at the back of the boiler which is accessible from the underneath. It does not appear to be from the thread...
Hi I moved into a property where the pressure is slightly low and they have this super duper shower but pressure is somewhat lacking. I have had water company out and they did do a check and they found the flow rate reduced but they mentioned about the inside stopcock/tap should be changed just...
Hi all. I recently upgraded our CH system, but rather than the expected drop in gas consumption, Octopus is saying we're using roughly 30% more! The installer has said they can downrate the boiler, but to my mind that addresses maximum consumption, not any inefficiencies there may be relating...
