Discuss New April 92% ErP boilers in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Npower have said they would fit a Ideal logic C30 combi boiler for my daughter under the energy saving improvement plan. Does this boiler comply with the new April directive of 92% ErP and is this boiler any good.
Thanks Harvest, does this mean it does not comply with the new ErP and should not be fitted
I believe so but as I said before I could be wrong. But my understanding is that it needs to be 92% without controls.
I thought the controls/ weather comp / fghr upped the percentage
Thinking back to the erp labels ( I didn't do many)
You added all the bits together and got a combined figure
91.1% my understanding is adding suitable controls raises it to the required efficiency of 92% level Gross just looked on installer connect it says says as below ?. kop
I’m sure that I saw somewhere that you couldn’t use controls to bring the ERP up. I will look into it but also just saw this. So what does this mean
It says homeowners must then select not including
Just remember it is only the space heating element of the boiler that needs to be 92%
You HAVE to look in the boilers MI’s at the ERP data, it will give you the space heating seasonal efficiency figure, which is the figure we need to be 92% or above.
The Logic Combi range has 94% space heating seasonal efficiency.
All manufacturers will be ensuring boilers are upto this level as standard. You won’t fond that many that aren’t already.
You will be fine with the C30 it’s a good boiler.
See below for highlighted figure from MI’s
Reply to New April 92% ErP boilers in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can anyone recommend a decent multi meter, preferably under a 100 pounds. It's for checking boiler components so I don't need a top spec one ....just easy to use and reliable. The fluke 115 looks good but its above my budget. My current socket and see one was great but it's developed a fault.
