Discuss Neff Dishwasher Aquastop Connection Question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
snowpony
Hi Lovely Plumbing Community,
Please help me. I have bought a NEFF dishwasher (S51E50X1GB) and am installing it myself. My previous dishwasher was also a NEFF and a similar model, so I thought it would be a simple swap. When I removed the old dishwasher I noticed that there was a brass ending to the aquastop that had been connected very tightly to the water connection. I used a wrench to undo it from the water end, but couldn't find a way to remove it from the aquastop itself - so assumed it was part of the unit.
When the new dishwasher came its aquastop was entirely plastic. Knowing no better I screwed it straight on to the water connection, but when I turned the water tap on the connection between water tap and aquastop is in no way water-tight: water gushes out!
I assume that I need some kind of adaptor or connector to create a seal between the two. I'm assuming a brass bit with a rubber washer, but have no idea what this is called or where to get it from. I called NEFF direct, but they couldn't advise.
This is my first attempt at installing a dishwasher and I really want to be able to complete the job. Advice happily welcomed.
Hi snowpony welcome to the forums, did you use a washer to seal the aquastop to the water connection?
No, it didn't come with a washer and also there's a very small thread on the aquastop. Would I be using a washer that fits inside? I'm assuming it would be a rubber washer.
You sure the washer isn`t attached to the hose somewhere, normally with a rubber band.
ah! one of those neff things....
putting a house brick on the end of the pipe make things awkward for a start!.
do you have a picture?
Needs a washer either fibre or rubber, normally in the installation kit
Thanks. I'll take a look again at everything that came with it, but fairly sure one wasn't included.
If I need to buy a new one what am I looking for, size-wise?
9DDuFVu5-W2l0erCgOzwSDTKj5c_n0tgdQOvRRNLu9PFMol_8x284t60NVpqou3KRqwKdm9UzIVkcYCW3apPy6LuGG_yToCAQ6uFAOKiK9aPHZglkR6ccSVCOpW1fNjj358K6yqWl4ARnOAQVcz4Oy-53m8oReAr509us14_gH5yjVQFP-fhKl_Yb5qqR2E1rNJ6vSG9zwVBoH8YKMNWld1VuWpnvYee6kH674WoncjZj150gW69rkStY3rbwfzLX2-HHHdYkfMOEwuPONR5sj7ZgxsiuO14wjmA2_o6qOJNYzrel95ZQBNfeZzqTaMArK06ATO5zoV0V2MTAyCr6uQKbmbJLacRJFsUOpllyaE8r822G33qeLQ0SqMJVPpvSWwA99y7JmISP1zHONxskQe8L8ZlTazu01vvwca6piGLL1R4WoMSj_FJ4ZmSegPzXCfcOuZW10A7N4A2QRbLSQxleKzSJO8PSMdzOcDOrpCCzlnwQpZengnXYRrAnVaJgQ5Rw97PHxeYHZEqZlSRrjo2REs583L4pI535hgvPbrR4hqzRE6arkIIlF41xbTh_bSN=w982-h1308-no
urvpmJxJLw9fNZS532Lyyql_YWGwCwfxactsaNiAU1l7w6CtQeKPDGTJeoapl0qBF3SRUmANEHn2XyD_Su6-ndYCxh5UZUw_i4IY2DqNp1TkdgQIsjL4s_4DaJ1f4oSFEBqqTd93rx1zk6lu5t2c56yJf8jUwG4XwOx8E1rrg2j69N3zvVjeJA7dulIHzdK-acF6mdk5ryh2XMHiRdg_qJzDUB41GAhialWwN3nCIDm3nnTRByE71C1HDxdzltSfAgNh7YqDTAboPAZn34AtaiPCcMzIh39I89VAEo2hk_-pNzwpjJGBNgsxk-7_sZoUOlPOTRiw2N0dTudhjHcS6w3teR2ZdwW1xpayu13fMb3dG6qIf9J9J5vraGvClUO-f7_b4zgw1oPHW2NnxFoprTyI8Bza93RIq6enR6lOre_htjS8LYI5SphjZOrz0XBWLOloAB4w6c-vyBePso6sOVTkd0Mcfj09Z57tWI9Qc9oUTu9K3gCqvkJOfXq-9tVkf10syFUmI7mns9vH8jzDnAamfradRKKxRi230lZLYcLeuGhFK-YKkpMs7Vy90xbwENFH=w982-h1308-no
You can see how small the aquastop thread is in this picture. The black area inside is part of the filter and doesn't help provide a seal.
Do you really think just a washer is needed here? That would be really great if it's that simple.
Looks as if the seal is in the aqua stop ok. The old ones had a brass nut, the new ones are plastic. Make sure you haven't cross threaded the nut and try a few wraps of ptfe tape. Does it actually start to screw on or is the service tap too large?
It screws on and the fit always feels really tight, but the water gushes out over the top of the aquastop connection. I'm worried about ruining the plastic thread by trying too many times.
What does ptfe stand for? and would the tape be enough to ensure a secure seal?
Thanks for the advice.
They are a tight fit. When you screw it down keep wobbling the aqua stop. Tighten down until it stops wobbling then nip it up a bit more. Use a pair of grips. Ptfe tape is used to seal a thread on a fitting, get it from a merchant.
Thanks - and it's ok to use a pair of grips when the thread inside the aquastop is plastic - that won't hurt the thread at all?
And could you advise me on how to use the Ptfe tape? Do I put it on the tap before threading on the aquastop, or afterwards, around the top? Sorry if these are very basic questions, but I'm a complete novice and need all the help I can get :)
Post #1, he tried that and they couldn`t help hence why he is here.
What I meant was: if it's not screwing on it could be faulty be faulty. Perhaps you should contact the retailer. At the end of the day it is their responsibility if the part is faulty. Of course if you have cross threaded it, which is easily done if you have no experience, then you will need a new aqua stop. FYI I ised to charge £ 50 for a first time install including parts and £20 for a swap. Just saying.
ive had them to deep and hit the valve handle before there tight couple of extra washers workede
Reply to Neff Dishwasher Aquastop Connection Question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Easy if you're a plumber I guess, but if you have no plumbing knowledge? Its a Bosch, nearly ten years old I think, its door won't shut, so it...
N
Hi all, First off, sorry if this is appearing in the wrong place, but I figure I might get some unbiased opinions on here and perhaps some first...
2K
Straight
Morning. I have a leak. It’s coming from the connector pipe….the picture shows the pipe. It is a cold water pipe going in to the back of my...
Forgive my ignorance, with this basic question, but I seem to be struggling to both understand, search for, and source, the appropriate washer...
This issue arose about a year ago. Does anyone have an idea why I occasionally hear (about once every hour or longer) a hammer related noise...
