Discuss Need Help on Shower Drain in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi, I need some help on this shower drain installation. I’m about to install a corner shower kit in my basement bathroom. But I just found out the shower drain is actually extruded from the bottom of the shower base and I have concrete floor with the drain pipe rough in. I have the drain pipe roughed based on the drain location, but I did not know that the drain is extruded beyond the bottom of the base. I have been using screwdrivers with a rubber hammer to knock some of the concrete around the pipe to have some clearance. The drain had a rubber gasket with a locker and the plastic drain part has a lip which keep the rubber in place. So I am thinking 3 ways to install the drain and I am more inclined to the 1st method. Any comments or advice on this is appreciated.
1. Cut the bottom of the drain as the red line shows in the picture. Let the bottom of the concrete as retaining the bottom of the rubber gasket. Install as the instruction. The instructions did ask to have 1/2 inch from the bottom of the drain to the surface. But I am thinking do not let the plastic drain has contact to the concrete so there is some buffer for the drain to move on the pvc pipe up and down. It won’t be 1/2 inch. Will most likely 1/4 inch. Should I concern any leaking issues if I do it this way?
2. Cut a piece of plywood exact shape like the shower base which is about 1/2 or 3/4 inch thick, so it gives me some clearance for the drain installation. I will need to use a caulk tape to seal between the base and the floor. But should I concern the board could be unstable as the glass sliding door will be installed later on the base.
3. Continue to chisel the concrete around the drain pipe until it has enough clearance to fit the drain. If I do that, do I need to chisel further to have the 1/2 inch clearance? It could take me days to do this but I can do it if needed.
Thanks.
Bed the tray down on concrete mix should lift it up a smidge so it will go together without any cutting ?
thanks, how thick would the concrete need to be? The concrete will be just covered the base area, right?
Correct just the tray area normally just a slurry but you can go slightly thicker to help for the waste etc
Thanks. Would it be okay to pour the concrete on vinyl flooring or just on the bare concrete as I currently have? This room will have vinyl plank flooring. Not sure if put it on vinyl floor will be easier to do maintenance if I have any issues with the shower down the road? Really appreciate the insight.
On the concrete floor only
Have you got any photos to share of your finished project?
Reply to Need Help on Shower Drain in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Do you recognise this shower drain rubber seal? I have searched the web and common plumbing spares suppliers but I cannot find which it is. It...
N
Hey DIY enthusiasts, Just wrapped up a drain installation and wanted to share some quick tips for a smooth project: 1. Plan Smart: Think about...
Nasir Ahamed
N
Hello All, I have an issue and hoping someone could shed some light on the problem. We have been getting a smell coming up in the bathroom...
Hi, I have a few issues with my bath drainage and leaking. The first issue is that the near corner of the bath by the taps is sloped downwards...
