Discuss Name of this plug please in the Central Heating Forum area at PlumbersForums.net
New pump has this connector old one was hard wired. Would rather get plug than mess inside pump controller.
Should have come with the pump?
Thank you so much. Googled for ages with no luck, its the one that has three separates. Cheers
Reply to Name of this plug please in the Central Heating Forum area at PlumbersForums.net
Hi, I note that the Grundfos Alpha 2 requires a special plug to connect the electric wiring. Are those plugs reusable if rewiring is needed...
Hello everyone, Baxi Ecoblue System boiler which was recently serviced just before Christmas. There has since been a constant but slow drip...
Hi, We moved into a new property yesterday and are a little baffled by the heating/water tank situation. The previous owners unhelpfully left any...
I’ve just swapped these new valves over live. Didn’t realise how bad the old nuts looked until finished the job. Would it be hard taking these...
Hi all I'm blanking a couple of openings in a hot water cylinder. The Screwfix Flomasta 1" BSP plugs fit perfectly but no washer supplied or...
