Discuss My combi boiler keeps loosing pressure & the overflow is dripping in the Plumbing Jobs | The Job-board area at PlumbersForums.net
As the title says, sometimes my boiler turns it self off when it goes to zero pressure which happens quite a lot so I re- pressurise & comes back on all fine (heating & hot water). When the heating or hot water is on, small drops of water comes out of the overflow.
Also when I have restarted the boiler & the heating is on for awhile I'll go in the loft & the boiler has turned itself off with zero pressure but still overflowing.
It sometimes drips from the bottom of the boiler when heating is on.
Lastly I have bleed all the rads in the house.
I'm wondering if it's the pump?
Feedback would be appreciated
Sam
No not the pump I would say you have a leak somewhere on your system that's why the pressure is dropping
Do you know the make and model of your boiler ?
Well the overflow is dripping & I can't see where the water is dripping from within the boiler
Any chance of a pic of the pipe that's dripping?
A
Ahhh man wish I could but I'm at work till tomorrow. As soon as I get home I'll take a picture for you. You got an idea roughly why it could be leaking pressure? My boiler was loosing pressure before it started leaking from the bottom
A
Depends where it's coming from tbh the easiest way would be to call a gas safe engy on Monday
That's the annoying thing I have done but made it worse because after he fiddled about, boiler now goes to zero & leaks from the bottom which it didn't do before he came
That's the problem these days finding a good gas safe engy if you don't mind where are you located roughly
:D it's a beautiful place
It's worth a post in our find a heating engy section maybe one of our members is close by
Looking for a Heating Engineer? Post Jobs Here
Haha. It's a tricky 1 as the gas engy is a family friend but lives 40mins away & doesn't want to be going backwards & forwards with the wrong parts. So he said to me that I need to get hold of Worcester to see if they know what the problem is & he'll fix it but I bet they wouldn't know or tell me over the phone/email till they've got their own engy out to have a look
They do a fixed price repair ;) might be worth looking into if you can't get anyone locally
You need to get a GSRI to check your boiler and repair and sevice it regards kop.
I am just as qualified as any other gas safe person as I am gas safe registered but my post was deleted as I haven't posted 10 posts, when did not posting 10 posts make you an unsafe gas installer ?
If your friend is Gas Safe and knows what he is doing he would know exactly what parts to bring with him from the faults you are describing. I would find another fitter if I were you.
Worcester came out to sort it out & he said it was the PRV that was the problem, change that & a few other things. Now working normal again. Thanks for all your help everyone
Ta for the update
Reply to My combi boiler keeps loosing pressure & the overflow is dripping in the Plumbing Jobs | The Job-board area at PlumbersForums.net
