Discuss My combi boiler keeps coming on even when the remote thermostat is turned off in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Samranda
Over the last 2-3 weeks for no apparent reason, my boiler has started turning itself on (mostly at night) even if the thermostat for the central heating is completely switched off.
Can someone explain this. My boiler is Worcester 24i Junior
New install??
Is it coming on then going off or warming as if the heating is on??
Put it in eco mode and see if that solves it, they do come on every so often when not in eco mode.
Although it will take longer for your tap water to get hot when you use a hot tap.
Yes it is. The thermostat receiver is showing a green light when the heating is coming on and then red when it switches off but the thermostat remote is completely switched off as it was all summer
Sounds like frost protection.
Could be something as simple as changing the batteries in the remote unit. They might be on the way out and causing the unit to send an on signal when it's not meant to.
Because some comb boilers, although not having a 'tank' do have a small hot water 'cache' they keep hot 24/7, so they will fire up at random times to do this. You can disable this feature using the set up menu as I have done. The down side of doing this is that is seems to take forever to get hot water so you waste more water in 'run off' and pay your water supply company for the privilege, before you get the hot water you want. You cant win, the utility companies win, but that's what they are for, to supply cash dividends to pension companies so anyone who has an occupational pension, all the local authority employees and MP's for example, will continue to get a good pension at your expense!
Reply to My combi boiler keeps coming on even when the remote thermostat is turned off in the Plumbing Jobs | The Job-board area at PlumbersForums.net
