Discuss Multimeter & Single Wire (DUMB QUESTION ALERT) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
jaydebruyne
Can you test voltage on a single wire using a multimeter?
If so, how?
I know this sounds like a dumb question but, say I want to find out the common wire on a cylinder stat. Do I just put one probe on the single wire?
(I don't have anything I can test here at home...)
You need to connect the multimeter between the wire under test and a known neutral or earth.
But, if the circuit is protected by an RCD then if you go live to earth it will trip the RCD?
I think thats if multimeter is set to ohms? Voltage shouldn't trip it. Someone else can probably confirm if i'm wrong.
And if there is no earth or neutral wire? How do I test what voltage is on each wire?
you can touch to pipework as that is usually earth but dont set the meter to amps and touch live and cylinder unless you want a probe sized hole in the cylinder and a shorter probe on the meter
The multi meter is testing the voltage difference between the probes.
you can get some voltage indicators that will tell you if voltage is present with a single probe/ single phase test. If you Think of thos screwdriver testers where you would put your thumb on the end to make the neon glow.
Something like the fluke t150 for example, I have one that cost me about 40 squids that does it.
or Di-log combivolt tester. A light on one of the ( joined together) probes comes on when you touch the / a live wire. Nothing with a thumb over the end.
Touch it with your tongue
Masood,
Everyone knows this is not correct procedure, as there's a risk other cables could touch your face. The correct way is to lick two fingers ( thumb and first finger work best ) and gently dab cable, if it tingles it's live!!
There is always an earth somewhere, try the screws on a nearby socket.
Neon testers can be deceptive, lighting up as low as 50v
Reply to Multimeter & Single Wire (DUMB QUESTION ALERT) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I have a Honeywell ST699 programmer which is working fine but I want to learn how to decommission it (disconnect it from the rest of the...
HI folks, this post is a follow up to my post relating to my single pipe heating system. In summary, I have a house built in 1980 (I bought it 2...
Background I have a small one-bedroom flat in the roof space in a victorian house. There are three floors below and each floor has a single...
Hello all I'm replacing 2 unvented cylinder a which are (a) end of life and (b) installed in a way which is clearly not right (no 2 port shut off...
Hi I have a normal on/off thermostat connected to my Ideal Vogue Max 40 and have been looking through the installation manual (here) to see how...
4K
