Discuss Multimeter help in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
Rheogra
Hi, there.
I am considering buying a multimeter for my father as a Christmas gift. if anyone here owns one and could give some feedback as to there accuracy and quality. Thanks in advance.
Those from Maplin are good though at present I'm using a Martindale meter with fuse protected leads.
As Croppie says, it depends on your budget.
It depends on what he would use it for, I have had a Fluke 116 for a few years now and it has been great.
There are a few old threads if you do a search and some other opinions on what people use.
I use a Fluke 106 which measures micro Amps, which is a useful feature for boiler diagnostic work. It's quite pricey but really nice to use. Really depends on what he's going to use it for.
I bought a Mastech for twenty quid, Chinese but surprisingly okay for the money.
You might want to consider a clamp style multi meter, handy for current measurement if your a little nervous about doing such, as it uses induction so no physical connection required to the circuit. They have standard leads for voltage and resistance measurement.
Can get a half decent one for around £50 or so.
Gary
Reply to Multimeter help in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
Hi, My current hot water system needs to be replaced. Anyone got any suggestions or can recommend any plumbers around Derrimut area that won't...
