Discuss Multimeter Advice in the Plumbing Jobs | The Job-board area at PlumbersForums.net
dcollie87
I bought a multimeter online from Maplin. It works fine but when it comes to boiler fault finding I sometimes find it hard to push the testing points down the PCB connections as they are quite fat, especially on some of the newer boards which have really thin wires.
Can anyone recommend a brand they use which has thin testing points? Ideally small enough to fit in my tool bag too!
you can buy thinner longer un insulated leads from maplins or online but be careful with them - in the past I have used a knife to remove some of the plastic on the probes to give better ends
Thanks, does anyone know a brand other than fluke? The leads set alone cost £85! Is there a cheaper brand on the market that are reasonably good?
As advised by tb and awheating I got the ryobi Also, good kit.
I am also after a reasonably decent/priced multimeter, is the ryobi mentioned the 'RP4020'?
That's the one mate.
Got a decent set of test leads from Maplin.
No point on getting a fancy all bells and whistles multimeter with masses of functions when all you need to test is AC, DC voltages, motor capacitors and resistances.
I've got a fluke 116 too, it is slightly more expensive but to me was worth it
Reply to Multimeter Advice in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Locked
Looking for some help here - not my boiler, so consider me a proxy. I'm also by no means a heating engineer: I'm just looking for pointers, as the...
I'll pop this into the general advice forum as it seems the most active, but mods - feel free to move if there's somewhere more appropriate. Thank...
2K
Hi all, We recently purchased a house and nothing seems to work correctly here, I've spent weeks rectifying issues. Plumbing, electrical...
5K
Hi all First timer here - after reading a lot of the advice present I thought it would make sense to get stuck in and throw something into the...
2K
Aquarius
A
We have gutted the bathroom back to bare brick. But to find a good quality toilet and bath is a nightmare. I think I have sorted it and then...
3K
