Discuss Moving Radiator in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
TORMULA
I need to move a radiator but dont want to drain the system to do it. Is there any thing on the market that will allow me to connect the new pipework to the existing radiator valves?
Thanks.
You can plug feed/vent or pipe freeze if not drain down.
Reply to Moving Radiator in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have an old steel water mains pipe (approx 45mm) that I need to connect to a new pehd water mains (25mm). I can't get at it to create a new...
