Discuss Most valued tool...... My phone in the Plumbing Jobs | The Job-board area at PlumbersForums.net
E
Ermintrude
Alreet? Yeh my phone !
Any suggestions / reviews on phone cases? I'm on iPhone 4s with griffin survivor case - it's lasted 400% + on any of my last phones and I've had just about every "rugged" phone on the market for the shark fin sony Ericsson to motarola.
Getting iPhone 5 for free so what case?
Nokia 3210 just don't leave it on vibrate! I switched my old one on a few months ago nearly flattened a tower block 3 miles away
Only problem I get with the above case is that it select voice activated dial on its own a couple of times a day fm my pocket, really annoying, yet to find a way of binning voice activated mode, ie double pressing the main button!!!!!!!!!!!!!!!!!!!
Lame if you have the griffin survivor case I had the same problem with activating the home button and putting voice control on right pain in the arse.simple solution is there is a raised rubber part that fits in the home button (don't cut it out just cut it of level at the back) you can still use the home button with the case on you just press it further it works fine.
The bit where the pen is on photo if that helps.
I had one of those style of cases, only problem i found was folk struggled to hear me on loudspeaker.
Not to keen on iphones i prefer s4 or s5. Last year first day i recieved my galaxy s4 i dropped it on concrete and screen shattered so i phoned vofafone and said i cant believe it ive just opened the box and ive a shattered screen so they sent new one out. I felt guilty for 5 seconds for tellin a porky. So the protectors are worth there weight in rubber . Put insurance on fone straight away. Use mine as my buisiness filofax....
Just upgraded from the galaxy note to the note mini. I had a cheap rubber case off the market and the note has just turned 2 years. My other ohone is a jcb sitemaster, doesnt do fancy things but its bomb proof. I left it on the roof of the van a couple of years ago. It fell off, was run over and then found. Apart from a little rubber screw cover its still going strong.
Take a look at OTTERBOX phone cases.
I have an Otterbox rubber sleeve case on my old IPhone which is good & nice to grip, but I can't comment on others.
My most valued tool is my radio. Makita bmr 104 is first tool in and last tool out . Also when the customers arent in then i love to turn volume up and sing my heart out . Xfactor here i go . Not
Reply to Most valued tool...... My phone in the Plumbing Jobs | The Job-board area at PlumbersForums.net
PSxxxxxx
