Discuss Miscellaneous Overflow pipe in my cupboard! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Powada
This is just a query, it isn't causing me a problem, but in the cupboard which houses my water tanks and is behind my bathtub, there is a sawn off extra overflow pipe. Here is a picture of it.
It's been blocked off inside with a silicon of some kind.
May query is why would this be here and what is it?
Probably a basin waste, then change position ?
It appears to have flowed down from a previous hot/cold water tank - is this possible? And then it was just left and filled in when things were replaced?
What is the 1" 1/2 pipe connected too, is that coming from cold storage tanks?
Yes it is! Is it just an old pipe from a previous tank that a less than scrupulous plumber didn't get rid of properly? Or is that common practice?
Do you live in scotland by any chance? overflows of this size are only normaly encounterd there.
It may be that the original 1" 1/4 was not big enough to take the water away, so he up-graded?
Or you must have hell of a tank, or it is a long distance to feed out side?
Perhaps he was going to fit something up in the loft? May be it was going to vent something ?
Maybe he wasnt sure like me! Are you sure that 1" 1/2 is an overflow
Reply to Miscellaneous Overflow pipe in my cupboard! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
