Discuss metal stud in the Plumbing Jobs | The Job-board area at PlumbersForums.net
snoopy8888
came across this situation when installing flue. Metal stud in the way, can't move boiler to the left because of side wall, or right because of door opening.
Is this the way new houses are built now ? outside brick wall, insulation fixed on one side metal frame then plaster board fixed on the other side of metal frame.
Dry lining with metal framework instead of timber
Do Not What ??????????
Fix a piece of ply to two studs or slip some timber down the gap and screw through
this is an outside facing wall not an internal partition wall. I am trying to core 5" hole for the flue. The metal stud at the position of the flue exit.
looks like storm strapping cross bracing stud walls
Reply to metal stud in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, this is probably a daft question but I need to run my cold feed from one side of my wall mounted boiler to the other. Running it beneath...
