Discuss MDPE in concrete in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
Jim4093
I've extended my mains water mdpe pipe through into my new extension and brought it up through the slab under the new kitchen window. However, I've had to change my kitchen window into a set of French doors and so the pipe is now in the way. I want to break into the slab back down to the dpm that is on top of my rigid insulation and redirect the pipe to where the sink will now be located (approx 500mm away). Is it possible that if i do this can I just pour concrete over the pipe and connectors? Or does it all need protecting? It's a 4" slab so I haven't got room to lay the pipework in any ducting or use pipe lagging etc. I just want to make sure that the concrete won't damage the pipe or connectors. Any advice would be greatly appreciated.
Thanks for your help.
Jim
dont use a connector under concrete, just a complete length of pipe, best its laid in conduit to a protect it and b allow for changing it in the future if things go wrong
2nd the above.
You would just be storing up probs for later if you buried the connector in concrete.
as above do not and i mean Do Not put connection where you can not have access to them, or if you do be prepared to rip every ting out when it leaks
in an ideal worldthere shouldnt be connectors in the concrete but do you mean concrete or screed ive buried lots of fittings in screed without problems and as tamz said some times you need to pish with what you have
Reply to MDPE in concrete in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, In the process of a new build and we have routed a MDPE pipe through a lintel in the DPC but unable to bend it to the correct location due to the bend radius. I have now made the bend radius suitable for the bend but the pipe has no support underneath. Will it be better to put in a 90 degree...
2K
Hi all, we're doing some renovation work to our property and we wanted to install a sauna house (includes shower) in the garden, irrigation system and outside tap. I've ran a 25mm MDPE from the inside utility room where the main stopcock comes into the house. I originally thought that it was a...
2K
As part of a slow DIY bathroom refit I've removed the old toilet from the original location next to the soil pipe (and obviously capped off the branch) and plan to place it the opposite end of the room. I was pretty lucky to find a 110mm sewer waste pipe below the old sink which is the new...
Hi, I've recently bought a house and the drain is open in the conservatory. I think it's an old clay grey water drain and has the pipe from the kitchen sink coming out the wall about two feet up and running straight down into it. My idea is to redirect the pipe to come out the wall under the...
3K
