Discuss MagnaCleanse And Microbore Pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
DJB
Hi I am considering getting a MagnaCleanse as I have had a quote for a boiler replacement accepted on the condition it is flushed using one.
The worry I have is using the vibrating hammer thing that comes with it on rads on microbore systems, as I have visions of it dislodging lumps of muck that then get stuck in the first inaccessible bend or kink in the pipe!
Any thought or experiences ?
Thanks Dave.
then get some other quotes with just a chemical clean.
is the current set up badly sludged up, radiator's cold at bottom etc
Hes a plumber.
get a disclaimer of the issues.
or you could say you will leave it on with the chemicals for a few days and not use the hammer.
explain the high risk of blocking the pipework if you do.
no waiver, no work :)
Sorry probably didnt make myself clear I am the one one who will be fitting the boiler and the customer is the one who wants it flused with the MagnaCleanse, this system is 22/15mm so no problem there. But if I buy one then obviously I will want to use it on othere jobs some of which are microbore.
i just spent 3 minutes typing the same post as killy bing!! lol...but Good advice there whack some cleaner in for a few days and check the bottom of rads for heat as he says.
Hi DJB
You might like to sign up to the Adey Installers club - they are offering quite a nice incentive to buy a machine.
And don't buy one without dropping me a PM first - assuming that you are a genuine tradesman, which I am guessing you are. We think we have the best deal around on Magnacleanse.
As for your question - I will have to leave that to the techie guys. If you use the search box, you will see plenty of talk about the magnacleanse machine, but I dont remember anything about the specific question you ask.
Ray
ADEY said this when I asked them the same question "Yes the unit does work with Microbore pipes – granted, it takes a little more time but it is possible and works effectively."
Well if that comes in writting they will be paying for any repairs or extra time incured on the job.....i dont think. Id still stick with a clean first.
We use it with micro all the time due to fact that pf bursts manifolds . 1/2 fill system (don't bleed) loads of x800 and two days later use hammer. Sludge usually in nice small bits.
Reply to MagnaCleanse And Microbore Pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
The system is about 20 years old and has never been cleaned. The radiator water looks like tar and several radiators are warm at top and cold at...
Hi everyone. I'm currently working on a job for a customer. their radiators are not all heating up. in total there is 12 radiators. 4 of these are...
J
Boiler broke over Xmas and needs replacing and I’m tempted to move away from our 1985 gravity fed system and get a combi as many other parts of...
Jack Canfield
J
[ASIDE: I did wonder if this was the best forum for this but figured as it was a boiler related issue that the gas engineers would be dealing...
I have just moved into a late 1990s new-build house with a small bore (about 1/2" OD pipes) gas fired boiler central heating system. All the...
