Discuss Magna Clean or Fernox TF1 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Dannypipe
Subscribed
Hi peeps, don't know how many of you fit or clean these.
I've always stuck to the Magna Clean filter, but the TF1 looks easier to install and more user friendly. The question I have is, does it work as well.
I've always been amazed by the crap that the Magna Clean filters grab, even if it is a mucky job. Is the magnet in the TF1 as big or as powerful.
Possibly I'll have to take one apart and have a butchers!
Cheers,
Dan
fitted my first tf1 last week not impressed leaked from the large o ring strait away prefer the magna cleans but a bit concerned on the o ring and iso issues
I've just fitted a TF1 with my new boiler and I'm very happy with it, it's so easy to use. I'm also pretty sure it came with a load of different seals to use if mounted in any position other vertically.
Ditto the one I fitted recently was also supplied with horizontal adaptors. I don't normally bother with them though not convinced they do that much good. I have never been back to an install yet with a sludge problem. I just follow the boiler manufacturers flushing procedure.
I fitted a magnaclean today after fitting quite a few TF1 filters over the last few months.
Got to say i won,t be fitting many more Magnacleans, The TF1 filters are so much better and much better to fit.
What are these new "Magnaclean Micro" filters I have seen in the merchants? Anybody used one?
Speaking to a BG engineer today he tells me he doesn't think much of the the Magnabooster 2 that they are now fitting. He told me that they dont seem to collect much.
The magnabooster2 is nowhere near as good at collecting sludge, just built better but if they don,t work then there is no point in fitting them.
I usually use the magna clean professional 2 but I recently fitted one of the Fernox omega TF1. The jury is still out at the moment as I have not been back to service the boiler yet. I do like its construction metal body, filter and magnet. It can also be fitted vertically, horizontal and also rotated 45 degrees if space is tight.
I have been thinking about this as I prefer Spirotecs and I was trying to understand why every one else prefers the Magnacleans and the Ferrnox TF1. I realise that these units are ok when used with domestic boilers up to 22mm pipework, but when working with heatpumps on 28mm pipework these units no longer become fit for purpose as they restrict the flow rate.
So I definatley recommend the Spirotec Magnabooster 2 every time
You can buy a 28mm Magnaclean. Give one ago.
as above you can get a magna from 22mm, 28mm,35mm and 42mm
Reply to Magna Clean or Fernox TF1 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
