Discuss Low Water pressure area in the USA area at PlumbersForums.net
bluesky
Dear all, I have a question please kindly help me. The job is in rural area and has very low water pressure. There is no gas here. The customer is thinking to install an electric combo boiler. The problem is the minimum pressure for electric boiler is 1 bar. How can I fill up the combo system? Can I buy Something like a pump to increase the water pressure. I don’t have this kind of experience. Please kindly help.
Thanks guys
When incoming pressure is poor ie less than 1-1.5 bar then you should consider mains booster pump and a break tank.
This will have a stored amount water in the tank with an air gap to prevent backflow into mains boosted by the pump to a set pressure.
I'm not a plumber (oil heating engineer) so have not done this type of install but if the incoming pressure is that poor then this is the type of setup you should be looking at.
Depends if you just want to fill up the heating once a water pressure testing pump will do that eg rp25
mainsboost any good to you ?
Reply to Low Water pressure area in the USA area at PlumbersForums.net
Pumps and low pressure I moved the bathroom to the back the house (next room) upstairs. I put in two pumps because low pressure water area. One...
I have been facing central heating low pressure on unvented hot water RM Cylinders but can't see any leak on the PRV, expansion vessels and...
losing pressure
L
Low hot water pressure Hi everyone, I'm hoping someone is able to shed some light on my situation before I have to call out the professionals...
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air...
