Discuss Low system pressure causing overheat? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
MarkOil
I went to a boiler the other day where the limit stat had tripped (Grant Combi 21).
Found the system pressure was at about 0.5 Bar, and very little air in the vessel, so re-pressurized that, and topped up system pressure, all ok.
Now my question is, is the low pressure the cause of the limit stat tripping? or a possible cause?
If so, surely the control stat would of kicked in and shut the burner off?
I did test both the control and limit stat, and both work and shut off as they should.
It ran fine and when reached temp it all closed down as it should.
Anyone got any views or ideas?
Reply to Low system pressure causing overheat? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I have a Glow-worm back boiler which is giving me grief (I would have upgraded it by now but its a listed building and there's issues with...
Have a sytem boiler with unvented cylinder with 2 heating zones plus hot water in a house we moved into recently. To start with we were always...
I have a conventional system, Potterton Prima Boiler, into a Pump into a Motorised Valve that feeds the Radiators and/or the pipes in the Hot...
Hi, Over the past few months, my wife and I have noticed a constant pulsing sound throughout the house which is particularly noisy at night (this...
I have a Vaillant eco plus 837, year installed 2008. It works well. We have one large zone for the house with 13 rads running off it. We also...
