Discuss Loud whistling when running the shower in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Our heating system has started whistling very loudly when the shower is being used.
If I run a cold tap, the whistle stops immediately.
If I run a hot tap, the pitch of the whistle changes.
The noise is not coming from the boiler (Ideal Icos) which is in the kitchen, it is coming from the 'tank' (A-Class BoilerMate OV) in the upstairs airing cupboard.
The heating system was installed 12 years ago ('new' build), but the shower which is a bar-type, was only installed about year ago (replacing a previous bar-type shower)
It only seems to happen first thing in the morning.
Any thoughts?
Pin
Possibly the ball valve and float in the hot water tank in the loft?
I don't have a tank in the roof/loft, but there is a small tank in the airing cupboard on top of the main tank. It looks pretty grim inside.
Some pics:
Thank you.
Pin
*edited pics*
Reply to Loud whistling when running the shower in the Plumbing Jobs | The Job-board area at PlumbersForums.net
