Discuss looking for plumber in NW7 london in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
RahulM
Need to drill a hole(10mm diameter) in Granite worktop
Can you please provide the quote?
Post this work also needs to fit a water filter which is a easy job.
Would appreciate if you provide 2 sepeare quotes for this work
Thanks.
Thanks for using the forums to place you plumbing requirements RahulM
Any members who can assist ,please contact the op direct
Reply to looking for plumber in NW7 london in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Can anyone advise as to why the cold water to my bathroom keeps airlocking? This originally happened about 12 months ago and has happened 3-4 times since. Itā€™s an upstairs bathroom, fed from a tank in the attic. The tank is about 8 Meters away and feeds a bath, sink and toilet. The tank...
Hi. I need a new toilet supply line but donā€™t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic nut about the same size as the one going into the cistern but has a different thread. Attached is a photo. Can you advise. Thanks.
