Discuss Logic 24 - hot water only turns on radiators in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
When I turn on water only on the logic 24 boiler the water heats up and so does the radiators. It’s a a single floor apartment with the boiler recently serviced and the safety valve and 12 litre vessel change.
Using the hive heating system.
Reply to Logic 24 - hot water only turns on radiators in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi all. I noticed this winter my living room rad only get hot in the top half. Radiator is 1600mm(DP SC) double panel single convector. System...
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new...
MartinPod81
M
hello we have an unvented system. we have an issue where the hot water is hot for 10 seconds and then luke warm, turn off taps / wait and turn...
Afternoon. I have an issue with no water flow from any of the hot taps in the house, I can't seem to find a solution to the issue. System is a...
