Discuss Loft location at a higher point than soil vent in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
DavidLoft
Hi there
I have an existing soil stack on the side of my house. I have extended the house by building a loft.
The loft company ran the waste from the loft over the roof straight into (i.e. closing off) what was the soil pipe - and added an AAV at loft level.
However now I am reroofing and need to move the soil pipe.
Can I convert the main waste back to open vented and run my loft into it as a branch connection EVEN THOUGH the loft itself is higher than the soil pipe vent opening height?
The branch would have the necessary slope and I would be be compliant with 900cm rule.
Reply to Loft location at a higher point than soil vent in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
