A
alig31
Hi all,
I have a radiator that I would like to put a lockshield with a drain down on it as it is the end of a line rad. Issue is that I need a straight through lockshield because of the routing of the pipes. Can you get a straight through lockshield with a drain down, or as another option can you get an in-line drain down that I could fit further along the pipework, so cutting a section out of the pipe to fit an inline drain (if there is such a thing.)
Open to any other suggestions.
Thanks in advance.
Ali G
Thanks in advance.
Ali G
