Discuss Lockshield replacement advice in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I'm redecorating the front room and have found one of the radiator trv leaking when adjusted, so I have decided to replace the trvs on all three radiators given there age, should I replace the lock shields also?
Your draining down so yes 15mm or 10mm ?
Yep there the ones I use downstairs I fit the drain off type
This may sound like a daft question, but how do you remove the control knob to convert it into a lock shield?
I'm not sure if it is a one piece molding, or is that a cap or a flash line? there is no way to prise it of
Reply to Lockshield replacement advice in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
