Discuss Linking 2 wood boiler stoves in the Plumbing Jobs | The Job-board area at PlumbersForums.net
H
harper
I'm looking into linking up 2 wood boiler stoves into a central heating system via a buffer tank. Is there a formula for calculating the buffer tank ?
thanks
steve
Total heat to water output from stoves = say 10kw x 40 = 400liters
Tks for reply.
I don't think we will have the space for that.
Has anyone had any experience of installing a SystemZone - [DLMURL="http://www.systemlink.ie/products/"]Products[/DLMURL]systemzone
Tks
Steve
Reply to Linking 2 wood boiler stoves in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, this is probably a daft question but I need to run my cold feed from one side of my wall mounted boiler to the other. Running it beneath...
Hi All, I am looking to take my bath out and fit a shower. Regards to tanking. Is it ok to just seal everything with plastic rather than just...
