Discuss Limit stat question? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
L
lazybee
Hello all , I just found your forum when having a google, I hope someone on can help me out?
my daughter's boiler has stopped giving hot water. The high limit stat has failed (open circuit). I can't get spares from the Manufacturer as they're from a French boiler marked and sold under the name of Leroy Merlin however all the internal parts are Italian. Leroy Merlin no longer supply parts for it.
The original limit stat (Thermo disc type) the range is: Close 105 degC open 150 degC. All the newer switches have a narrower operating range. I can get 120 degC to 150 degC. Does anyone think this will do as it will cause the boiler to fire up more often?
A virtual pint for anyone with a suggestion of advice,
cheers LB
We cannot and will not give advice on the installation or repair of boilers, cookers or ANY gas appliances for your own safety.
Please go to www.User PlumbersForums.net Instead - Copy the content, don't link to it.co.uk or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location.
http://www.ukplumbersforums.co.uk/im...-gas-engineer
If you are gsr please increase your post count to 10+ then send a PM (Private Message) with your gsr details to either Gas man -http://www.ukplumbersforums.co.uk/members/8668.html Redsaw -http://www.ukplumbersforums.co.uk/members/2718.html who will check you and then give you access to the gsr private forum.
Providing gas-related advice to anybody who should not be touching gas and cannot prove their competetence is unacceptable.
We will take whatever action we deem appropriate to prevent such advice being given.
Thank you.UKPF TA's, Mods and Admin teams.
[DLMURL]http://www.co-gassafety.co.uk/deaths.html[/DLMURL]
Reply to Limit stat question? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, this is probably a daft question but I need to run my cold feed from one side of my wall mounted boiler to the other. Running it beneath...
