Discuss Limit stat heat tester in the Plumbing Jobs | The Job-board area at PlumbersForums.net
magicno1
Hi guys
Looking for one of the testers for checking cut off temps of thermostats and limit stats. They are the electric ones that you stick the phial in a sleeve and you set the the temp and you can see the if the stat is shot or not.
any ideas of who makes them and where to get one???? I know they are quite pricey but you have to have one really not use a kettle!!!!
cheers
Teddington fire valve tester, do a google search you can pick them up cheaper than on oftec etc, I use my for testing all stats handy bit of kit!
Think I got mine from cranefords
Reply to Limit stat heat tester in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi guys....we have an old Astracast sink top....I think its a composite sink....has a big single bowl. My wife thinks it looks scruffy....looks...
