Discuss Life expectancy of header tanks and ball valves, relocate or replace. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I am going to move my central heating header tank and started to think about the life expectancy of various plumbing items.
The tank is polypropylene and has a brass ball valve with plastic float. It’s 40 years old. With the issues of sustainability etc, it’s it likely that these items will last another 40 years if moved? Is it a case of “they don’t make them like they used to?”
You don’t routinely think about replacing these items or copper pipework .... how long will they last?
As with a lot of things it will depend on how its installed in the first instance and how well it is maintained going forward It can be proper finger in the wind stuff.
They dont make them like they used to. My last house the tanks and valves where from 1948 when it was built and I moved the lot when I did a loft conversion in 2000 just sold 4 months ago. No problems except a valve washer. Spray the gate valves with wd40 or chainsaw oil a few days before you want to play with them
The plastic heating tank is better replaced. I have come across them being heat damaged due to systems occasionally putting hot water into the tank via the vent or feed pipe.
Remember one being so brittle I could just break parts of it with my fingers.
Same with large cold water storage tanks. Definitely the rectangular types need replaced as the stresses on the sides can and will eventually cause plastic to crack.
Round plastic tanks if installed correctly are capable of lasting much longer if no hot water or UV rays could damage them.
Also got to consider woodworm can damage plastic tanks, do do not assume if the tank looks okay, that it is
Round tanks are ace, especially when going thro a restricted loft access. We warm them up and squash them down so they fit thro. Rob Foster aka centralheatking
Never thought of warming them up.
Guess only safe way is use warm water.
Or a hairdryer carefully?
Reply to Life expectancy of header tanks and ball valves, relocate or replace. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, my Mothers heating failed in the recent UK cold snap. I found the pump was stuck. I have a question about pump orientation. The...
Been in property about 10 years and the valve on the (round/bunded) Balmoral tank has always been in pretty rusty state. Tank is 5,000 litres but...
1K
We live in a 1980s four-bedroom detached house. The time has come for new central heating. The current system is a mild revision of the original...
2K
We just had a waterhole bored and were lucky enough to find a flowing artesian, which delivers just over 500 gallons an hour without needing a...
So I bought my first flat recently (am in UK) and in a bit of a pickle as the bathroom has turned up lots of problems that weren't picked up by...
