M
mmccross11
Hi Folks,
Wondering if you can shed some light on how to remove my cold water lever tap. The problem is that I am getting no flow coming out of my cold tap. There is flow out of the hot tap but not the cold. I have managed to pull off the metal lever tap but unsure how to disassemble the rest of the tap. There is a blue shroud with a brass threaded section in the middle. Unsure how to remove the blue shrouded bit - do I just pull off to get access to the brass part? Then how does this come off?
I've attached a few pictures...
Thanks in advance,
Mick.
Thanks in advance,
Mick.
